By using the following code you can have the extension activate itself on a specific date.
ext/hifikabin/fredthebat/styles/all/template/event/overall_header_head_append.html
AND
ext/hifikabin/fredthebat/styles/all/template/event/overall_header_body_before.html
FIND
{% if S_INDEX %}
REPLACE WITH
{% set today = 'now'|date('m/d') %}
{% set halloween = '10/31' %}
{% if today == halloween and S_INDEX %}
Now you can activate the extension in the ACP but it will not become active until the specified date (April 1st if the default setting, to choose a different date edit
