[3.2][3.3][CDB] Fred The Bat (Cursor Follower)
Extension Name: Fred The Bat Image Image Image
Extension Description: Image follows the cursor around the screen of the index page, just right for Halloween. If the user has JS disabled then Fred will not work and is hidden from view.
Live Demo: HERE
Extension Version: 1.0.2
  • Prosilver
Notes:
  • The code is run every 120 microseconds and may cause problems with low CPU and low memory devices.
  • Why Fred? I had him on a phpBB 2 forum many years ago and someone called him Fred. The name has stuck
  • Options see HERE
fredthebat_1_0_2.zip
The contact us link at the bottom of this Forum or CDB topic
Re: [3.2][3.3][CDB] Fred The Bat (Cursor Follower)
Alternative Themes:
There are 3 other images in the .zip file below that you can use instead of Fred. To use one of them, unzip the package, then unzip the image you require. You will then have a folder called theme on your desktop. Disable the extension, and replace the hifikabin/fredthebat/styles/all/theme folder with the one you have just unzipped. Enable the extension and refresh your browser.
Image Image Image
alternative_themes.zip
To use your own image:
Save it to root/ext/hifikabin/fredthebat/styles/all/theme/images
root/ext/hifikabin/fredthebat/styles/all/theme/fredthebat.css
FIND
#fredthebat {
	position: fixed;
	background: url("./images/cursor_fred.gif") 0 0 no-repeat;
	margin-left: 20px;
	width: 75px;
	height: 30px;
	display: none;
	z-index: 100;
CHANGE
To your new images name
CHANGE
	width: 75px;
	height: 30px;
to those of the new image
SAVE, UPLOAD, PURGE CACHE
To show Fred on all pages:
hifikabin/fredthebat/styles/all/template/event/overall_header_body_before.html
hifikabin/fredthebat/styles/all/template/event/overall_header_head_append.html
FIND AND DELETE
{% if S_INDEX %}
{% endif %}
To show Fred on one or more forums ONLY:
FIND
{% if S_INDEX %}
REPLACE WITH
{% if FORUM_ID in [x, y] %}
where x and y are your forum id numbers. You can have as many as you like, just separate them with a , followed by a space. Note that the forum id's are in square brackets not the curly ones that contain the whole code.
To have Fred fly closer to or further from the cursor:
FIND
	margin-left: 20px;
CHANGE
20px to the distance required
1.0.0_RC4 now available.
  • Disable Fred The Bat in the ACP
  • Delete fredthebat folder from the server
  • Enable it in the ACP
1.0.0_RC5 now available.
Fred now appears on the index page only, and is hidden in small devices.
1.0.0_RC6 Image now available.
W3C errors corrected
1.0.0 CDB topic
1.0.1 Image now available.
Errors that prevented Fred from displaying correctly in RTL boards now corrected
1.0.2-RC1 Image now available.
Fred is now positioned better on the screen, Live Demo added HERE
1.0.2-RC2 now available. Image Image Image
1.0.2 now available. Image Image Image
Approved to the CDB
