[3.2][3.3][LATEST VERSION] Right Random Image
Extension Name: Right Random Image Image Image Image
Extension Description: Adds images to the RHS of your forum header (LHS for RTL language packs) Each image is randomly loaded and can direct to its own URL. You can set the links to open in a the same or new tab.
Notes:
  • Random in this instance means a random selection at each page load. There is no reference to any previously loaded images so there will be times when the same image is loaded several times in succession.
  • The image must be a standard image extension eg .jpg .gif .png etc
  • If you host the images on your own server, create a directory in the images folder in your forum root (where config.php is) called right_random_images in which to upload them. To ensure the image appears on all pages the URL for the image will then be http://myforum.com/images/right_random_images/image.gif
  • You can adjust the maximum size for images which shrink large images but not affect smaller ones
  • Compatible with my Google Search Extension
Language:
  • EN
  • Additional Language Pack: fr
Extension Version: 3.2.2-RC2
IMPORTANT NOTE: Versions 3.2.2 is written in a totally different way to the previous versions meaning you can have as many or as few images as you wish. If you are moving from 3.2.1 YOU MUST disable and delete the data from the existing extension before installing version 3.2.2 .
  • prosilver
Screenshots:
Live Demo: HERE
The contact us link at the bottom of this Forum or phpBB forum
rightrandomimage_3_2_2-RC2.zip
Re: [3.2][3.3][LATEST VERSION] Right Random Image
Additional Languages: fr
rri_lang_pack.zip
Additional Languages: ar, de, es, fr, nl, ru
Install Lang Pack:
  • Disable Right Random Image in the ACP
  • Upload the folder hifikabin to root/ext/ and re enable Right Random Image
3.1.0_RC2/3.2.0_RC2 now available
Improved switch to control if/where links open.
  • Disable Right Side Random Image in the ACP
  • Delete rightrandomimage folder from the server
3.1.0_RC3/3.2.0_RC3 now available
CCS Improved
3.1.0_RC4/3.2.0_RC4 now available
You can set the maximum image size in the ACP. Large images will be reduced but small images will not be increased.
Please note tha a large image may upset the alignment within Header
3.1.0 Now Released
CDB Topic
3.1.1-RC1/3.2.1-RC1 Now Released Image
W3C Validated, CDB Validation errors corrected. Compatible with my Google Search Extension
3.1.1-RC2/3.2.1-RC2 Now Released Image
Slight Code tweak
3.1.1-RC3/3.2.1-RC23Now Released Image
Code improved, written in TWIG
3.1.2-RC1/3.2.2-RC1 Now Released Image
IMPORTANT NOTE: Versions 3.1.2/3.2.2 is written in a totally different way to the previous versions meaning you can have as many or as few images as you wish. If you are moving from 3.1.1/3.2.1 YOU MUST disable and delete the data from the existing extension before installing version 3.1.2/3.2.2 .
  • Delete the data
