URL for the “Header Banner” ext?
I downloaded and successfully installed your extension for the header banner, but I’m lost at setting it up. Can you please give me some guidance on what I need to include in the URL for the banner?
Re: URL for the “Header Banner” ext?
From th screenshot you sent to me the correct URL for the banner is your boards url followed by
/images/bhavadasa/banner_ks.JPG
eg https://myboard.com/images/bhavadasa/banner_ks.JPG
(you start with the boards url, and every time you move a level through the file structure you add a / followed by the directorys name until you get to the image. It is case sensitive)
I tried the example you gave, but it still isn’t working. I was wondering if this is because this link is from my main page? I also added this, “Discussions”, but it still doesn’t work. I’ve also tried different images and they don’t work either.
What I’m getting is a blank screen where the banner should be and a little tiny box with a “?” In it.
Would emailing the configuration setting of the banner to you be helpful?
what is the actual URL of your board?
Fixed with the boards correctURL
