I note all my modifications in a .txt file.
I was told that, when possible, it is better to use a personal style, that is why I copied navbar_header.html from your extension into my style, I would have liked to do the same thing with overall_header_breadcrumbs_after.html but it does not work.
Finally I removed the link to Facebook which is redundant.
Notification and Private Messages text hidden
Re: Notification and Private Messages text hidden
You shouldn't need to copy extension files into a custom style, the extension should do it all by itself. If however it doesn't ( occasionally the custom style ignores the extension, or needs some style changes)
In this case the best course is to copy the prosilver directory in the extension and name it the same as your custom style
So in the extension you will have (for example)
- hifikabin
- headerbanner
- styles
- prosilver
- custom style
- styles
- headerbanner
If I do this My custom style only contains theme / custom style.css
Is it normal that my custom style / Template becomes empty as all template files go to the extension style ?
NOT your custom style but my extension
Have a look at the styles pack I have made for this extension to see what I mean
