Thanks,
you can grab the banner from here https://www.rudyv.be/Temp/Banniere.jpg and the logo there https://www.rudyv.be/Temp/site_logo.gif
Site Logo
Re: Site Logo
Got it
styles/prosilver/theme/colors.css
FIND
REPLACE WITH
ext/hifikabin/headerbanner/styles/prosilver/theme/headerbanner.css
FIND
REPLACE WITH
SAVE > UPLOAD > PURGE BROWSER CACHE
Enable site logo in header banner
(the above assumes that the banners URL is defined correctly in the extensions configuration and the logo is in styles/prosilver/theme/images)
FIND
background-image: url("./images/site_logo.svg");
background-image: url("./images/site_logo.gif");
FIND
.banner-header #headerbanner_logo {
float: left;
width: auto;
padding: 10px 13px 0 10px;
position: absolute;
z-index: 1;
background-repeat: no-repeat;
display: inline-block;
width: 150px;
height: 50px;
position: absolute;
top: 0px;
right: 0px;
Re: Site Logo
Still same problem but I've found a solution to make it work.
I have modified
it works now i.e. for screens smaller than 700 px it does not appear and from 701 px up it appears on the right.
Still a small drawback : the scrolling text is always a 150 px wide image so it always occupies 150 px : it is too big on screen smaller than 1200 px.
I have solved it by replacing
Thanks a lot for your help.
Rudy
I have modified
selector in headerbanner.css simply replacing float: left;
by float: right;
width: 150px;
with width: 13%;
Rudy
Re: Site Logo
Glad you have found a solution that works for you
