Hi admin iam big fan of you on the all phpbb forums today finally I registered here and find you
I have my forum forum i got error in the google serch console was everything is fine no error but last 1 weeks i face problem hope you help me
I use ext version 1.1.3
Forum version 3.3.7
Here is screenshot of problems
I hope answer my post
Regarding
Sitemap error on google search console please help
Re: Sitemap error on google search console please help
Good evening
The Sitemap is not an extension of my making, I just added the 3.3.x fix on this site until the author updated his extension on phpBB
You can find support HERE on phpBB but as a first setep I would update your board as it is two versions out of date, and also make sure that you have added the sitemap to Google correctly (ie the full url as shown in the configuration page)
I hope this is of help, or at least can point you in the right direction
Thanks for the reply boss iam trying on phpbb board but no one help and also deleted my post on phpbb board so why i come here ask help hereAdministrator wrote: ↑Tue Jan 10, 2023 7:50 pm Good evening
I add sitemap 100% correct i don’t know why problem coming
Here is photo sitemapp adding url Here is my htaccess file check it this is right??
Forum link here
https://sat-forum.net/
Thanks
OK, As a favour I will have a look for you.
Firstly, the sitemap does not exist which is evident by the 404 you get by going to https://sat-forum.net/sitemap.xml What you should be seeing is here sitemap.xml
Firstly I suggest that you disable and delete data of the extension before deleting the extension files.
Then download a fresh set from phpBB, unzip them on your computer (this is a very important point) before uploading and enabling. Then check to see if you can see the sitemap here https://sat-forum.net/sitemap.xml
re your .htaccess file, the ssl redirect you are using is different to the one I use, but everything else looks how it should. The .htaccess file I use can be found in This Topic which includes a Bad Bot blocking script
Was working fine sitemap look like your site open sitemap but last 1 weeks not workAdministrator wrote: ↑Wed Jan 11, 2023 9:11 am OK, As a favour I will have a look for you.
Here is sitemap not found status
This error on sitemap url
Exactly what I was saying. Have you removed and reinstalled the extension as I described?
PLUS what have you done to your board in the past week? If it was working but then it wasnt something must have changed
Bundle of thanks boss i use your posted htaccessAdministrator wrote: ↑Wed Jan 11, 2023 9:37 am Exactly what I was saying. Have you removed and reinstalled the extension as I described?
Now working fine sitemap
Sitemapp successfully connects with google search console
I want to support this forum please install thanks button in the forum
I have never used the "Thanks" extension on any of my boards, much preferring people to post their thanks in the topic a you have done.
In addition there is a 'Buy Me A Beer' button on the header should you wish to use it (you do not have to, I am just pointing it out)
