Hi!
Sometimes a picture is better than words:
AFAIK, it's only in the styles HexagonReborn and HexagonReborn Light (links here).
It's allright with Prosilver and Element, but I think it's obvious in HexagonReborn as Notifications are at the top of the page.
I can't find anywhere in the code a difference between the Sun and the Moon, so I'm asking you where's the problem. Do you have any clue, please?
[SOLVED] Sun over dropdown menu
Re: [SOLVED] Sun over dropdown menu
If you add
to sunspots.css that should fix the issue, remembering to purge your boards cache after the change
z-index: 2;
Hi Admin,
This is perfect! Thanks a lot. One more topic solved!
