Hi!
It's me again. In fact, it was another extension that masked the title and the description of the site. As I no longer need it, the title and the description reappeared...
My temporary site address: http://82.65.150.217:8080/
Can you do something for me, please?
[SOLVED] Cosmos banner and banner on the left
Re: [SOLVED] Cosmos banner and banner on the left
Element style?
Its working perfectly on my test board using Cosmos Banner 3.2.0 RC8
Hi!
Did you put a title and a description in your forum?
And I tried with prosilver: same problem.
Yup, its auto filled by the quickinstall software
What other extensions have you enabled?
I haven't the required pemissions to see that
Pwd : Azerty123!
Pwd : Azerty123!
Nothing leaps out at me as being an obvious cause. Try disabling Cosmos Banner and replace the files with a fresh download before re enabling
Nothing changed.
I'll try to deactivate all my extensions and start them again, 5 by 5, to see if there's a problem with one in particular. But not tonight, tomorrow at best.
Thanks for your help.
Yes, best start with a fresh brain
Good Luck
EDIT:- something you could try is deleting
from
Good Luck
<div id="cosmos_description">
<h1>{{ SITENAME }}</h1>
<p>{{ SITE_DESCRIPTION }}</p>
<p class="skiplink"><a href="#start_here">{{ lang('SKIP') }}</a></p>
</div>
ext/hifikabin/cosmosbanner/styles/prosilver/template/event/overall_header_headerbar_after.html
and purge the boards cache
