Hi!
Nearly everything is in the title. I'd like to align the banner on the left of the screen, that's all ! In fact, I'm using the banner as a site logo.
I know a bit about css coding so I can edit the file on my server, if it's easier for you.
Can you help me, please?
Moreover, is there a way to mask the site name, please?
[SOLVED] Cosmos banner and banner on the left
Re: [SOLVED] Cosmos banner and banner on the left
I havent tested it, but this should work
FIND
REPLACE WITH
SAVE > UPLOAD > PURGE CACHE
The Site Name should already be hidden, if it is not please send me a screenshot showing what you mean
hifikabin/cosmosbanner/styles/prosilver/theme/cosmosbanner.css
FIND
.headerbar .cosmos-banner {
display: block;
margin-left: auto;
margin-right: auto;
max-width: 100%;
display: block;
align: left;
max-width: 100%;
Thanks a lot, it works perfectly.
I blame myself for not having thought about it.
I'll mark the topic as solved.
You can be proud, your extension is a must!
Here is a preview of my future forum, still in development, therefore quite empty
See how useful is your extension!
Thanks, its niche but if you want that sort of extension its the sort of extension that you will want
Your site is looking good, I wish you the best of luck with it.
Really thank you!
Opening scheduled on january, 23rd. But as everything is late
Hi!
Here is the french translation for this wonderful extension: I hope you'll enjoy.
YES! that worked
I'll add it to the language pack next
At least!!!
Fine.
Fine.
