Good day!
Is it possible to move quick links to navbar?
How to do it?
Move header links to navbar
Re: Move header links to navbar
If I have understood you correctly it is an easy thing to do
FIND AND DELETE (around line 10)
FIND AND DELETE (around line 76)
SAVE > UPLOAD > PURGE BOARD CACHE
On a smaller a screen size it reverts to the previous state in order to not clutter the screen
root/styles/prosilver/template/navbar_header.html
<div class="dropdown">
<div class="pointer"><div class="pointer-inner"></div></div>
<ul class="dropdown-contents" role="menu">
</ul>
</div>
Thanks! This is also a good option!
But I wanted to move your extension there.
I am afraid that is a lot more complex and would need a total rewrite of the extension. So much so that it would probably be easier to write a new extension (for which I do not have the time right now)
Sorry for the bad news
Eh ... Again failure .. And the example that you gave for some reason does not work. The menu immediately collapses...
Just tested it on my live test board, and indeed it doesn't work although it does on my local test board.
Strange.
Strange.
