Uncaught Error: Syntax error, unrecognized expression: #
at Function.se.error (jquery-3.6.0.min.js?assets_version=748:2)
at se.tokenize (jquery-3.6.0.min.js?assets_version=748:2)
at se.select (jquery-3.6.0.min.js?assets_version=748:2)
at Function.se [as find] (jquery-3.6.0.min.js?assets_version=748:2)
at S.fn.init.find (jquery-3.6.0.min.js?assets_version=748:2)
at new S.fn.init (jquery-3.6.0.min.js?assets_version=748:2)
at S (jquery-3.6.0.min.js?assets_version=748:2)
at stickybar_goto.js?assets_version=748:3
at stickybar_goto.js?assets_version=748:11
I have done a little investigating and it appears that it is the JaveScript that ensures that the Header Bar doe not obscure the top of the post that i causing the issue. I am no JS expert but I will try to see if I can solve the issue. In the meantime if you want to remove the error you can do so by deleting one line of code
Re the Dark Mode extension, I have never tried it with that extension. My first suggestion would be to purge the cache again and purge your browsers cache.
If that doesn't work disable and re enable Dark Mode.
If that doesn't work let me know and I will experiment tomorrow
IgorCher wrote: ↑Sun Dec 19, 2021 6:22 pm
Yes it worked! Thanks are on the way (paypal)! Thank you!
But stopped working ext Dark Mode To change day and night, you need to reload the page. I will wait for a solution to the problem
I have done some experiments and can replicate your findings exactly.
What it happening is the JavaScript that controls the dark/light also changes the state of the switch on the navbar header. As the Sticky Header extension effectively duplicates the navbar header it confuses the Dark style switch position. (which is also why the Sticky Navbar does not appear in Dark Style)
The short answer is that I can not see of any way to resolve the conflict other than to remove the light/dark switch extension and to install a dark style which users can select in the UCP
