Header banner too large on mobile
Hervé
Post by Hervé »
Good morning,
On PC the banner is ok but it is too large on mobile; this is a mobile screen shot and the parameters used.
Can you help ?
Re: Header banner too large on mobile
The banner should scale to fit the available space no matter what the size.
Does my demo site work correctly or not?
A link to your board may help.
Hervé
Post by Hervé »
Where is your demo site ?
Mine is at https://www.LeForumRecifal.com
https://banner.hifikabin.me.uk/
I see what you mean on your site. Does it show correctly with the background colour enabled?
Hervé
Post by Hervé »
On your demo site the banner is OK.
On my forum with "hide the Header Background colour" = NO the banner is OK too.
I suspect that its something to do with the sidebar you have showing Recent Posts. I doubt that it will be easily to solve within the extension. The easiest way would be if you added a border to the Mobile Banner (maybe 5px wide) Then any cutoff will be of the border not the banner
Hervé
Post by Hervé »
The problem is not that the banner is truncated but that it is wider than the screen, therefore you can move the window a little to the left and to the right; I don't think adding a border changes anything.
I don't understand why coloring the background solves the problem.
It was showing as slightly truncated in my browsers, not scrollable at all.
Download and unzip the attached and use it to replace the file of the same name at
/ext/hifikabin/headerbanner/styles/prosilver/theme/
There will be a white border around the banner in Mobile Devices but the banner should behave better
headerbanner_background.zip
Hervé
Post by Hervé »
Yes, it's working fine now, thanks a lot.
No problem, glad to have helped
