Easy fix for 3.2.4 Known Problems
Odds and ends of code I have found useful
To make your life easier I have attached a zip containing the 2 changed files referenced in Known issues in 3.2.4
Download and unzip the attached. You will then find a folder called phpBB3 on your desktop. Within that folder there is another one called includes. Upload that to your boards root (where config.php is) and you will be asked if you want to overwrite bbcode.php and functions_content.php Accept that and the files will upload.
Then purge your boards cache, either from the ACP or (if you can not access the acp) by removing the contents of the cache directory on your server, leaving just index.htm and .htaccess
3.2.4_fix.zip
Re: Easy fix for 3.2.4 Known Problems
I will leave this here for reference, but please remember that the patch files attached above are for phpBB 3.2.4 ONLY
