[3.2][3.3][RC] April Fools (bugs in the machine)
Extension Name: April Fools Image Image
Extension Description: Adds flies and/or spiders crawling over the index page of your forum.
Drive your users mad :smt023
Sceeenshot:
Based On: Bug by Graham McNicoll
Live Demo: Extension Version: 1.0.0-RC2
  • prosilver
Download:
aprilfools_1_0_0-RC2.zip
The Contact Us link at the bottom of this Forum or phpBB.com
Re: [3.2][3.3][RC] April Fools (bugs in the machine)
Spiders Only:
ext/hifikabim/aprilfools/styles/prosilver/template/event/overall_footer_body_after.html
DELETE
	// default fruit fly bug:
	new BugController({
SAVE UPLOAD PURGE CACHE
Flies Only:
DELETE
	// default spiders:
	new SpiderController({
Show Everywhere:
AND
ext/hifikabim/aprilfools/styles/prosilver/template/event/overall_header_head_append.html
DELETE
{% if S_INDEX %}
AND
{% endif %}
Show on one or more forums ONLY:
hifikabin/aprilfools/styles/prosilver/template/event/overall_header_body_before.html
hifikabin/aprilfools/styles/prosilver/template/event/overall_header_head_append.html
FIND
{% if S_INDEX %}
REPLACE WITH
{% if FORUM_ID in [x, y] %}
where x and y are your forum id numbers. You can have as many as you like, just separate them with a , followed by a space. Note that the forum id's are in square brackets not the curly ones that contain the whole code.
SAVE, UPLOAD, PURGE CACHE
Also See HERE
1.0.0-RC2 now available.
Code tidied, Spiders and flies will not work if the user has JS disabled and are disabled.
  • Disable April Fools in the ACP
  • Delete aprilfools folder from the server
  • Enable it in the ACP
1.0.0-RC2. Confirmed phpBB 3.3.x compatible Image Image
