Using a bad bot blocking code in your .htaccess can help reduce this. There are 2 files attached, each contain the same Bad Bot Blocking code, but in different formats depending on how you intend to implement them.From the beginning of the month up until mid day today there are 209499 lines in the log. The first instance of this crawler was at line 106496 and lasted for the next 101750 lines. Thats 101750 hits in about 14 hours. A continuous 10 hits a second for 14 hours. All from the same ip.
No wonder the servers resources were overloaded.
The first is for non SSL sites, the second has the following SSL redirect which will redirect all HTTP requests to HTTPS and is only for use on HTTPS sites. They are a direct replacement for the default phpBB .htaccess and include all of the phpBB .htaccess data. Just download, unzip and replace the .htaccess on your site with the relevant one.
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI} [R,L]
The following is the Block Bad Bots code that you can add to your own .htaccess if it has changed from the default phpBB one.
# 7G FIREWALL v1.3 20200903
# @ https://perishablepress.com/7g-firewall/
# 7G:[CORE]
ServerSignature Off
Options -Indexes
RewriteEngine On
RewriteBase /
# 7G:[QUERY STRING]
<IfModule mod_rewrite.c>
RewriteCond %{QUERY_STRING} ([a-z0-9]{2000,}) [NC,OR]
RewriteCond %{QUERY_STRING} (/|%2f)(:|%3a)(/|%2f) [NC,OR]
RewriteCond %{QUERY_STRING} (/|%2f)(\*|%2a)(\*|%2a)(/|%2f) [NC,OR]
RewriteCond %{QUERY_STRING} (`|<|>|\^|\|\\|0x00|%00|%0d%0a) [NC,OR]
RewriteCond %{QUERY_STRING} (cmd|command)(=|%3d)(chdir|mkdir)(.*)(x20) [NC,OR]
RewriteCond %{QUERY_STRING} (ckfinder|fullclick|ckfinder|fckeditor) [NC,OR]
RewriteCond %{QUERY_STRING} (globals|mosconfig([a-z_]{1,22})|request)(=|\[) [NC,OR]
RewriteCond %{QUERY_STRING} (/|%2f)((wp-)?config)((\.|%2e)inc)?((\.|%2e)php) [NC,OR]
RewriteCond %{QUERY_STRING} (thumbs?(_editor|open)?|tim(thumbs?)?)((\.|%2e)php) [NC,OR]
RewriteCond %{QUERY_STRING} (absolute_|base|root_)(dir|path)(=|%3d)(ftp|https?) [NC,OR]
RewriteCond %{QUERY_STRING} (localhost|loopback|127(\.|%2e)0(\.|%2e)0(\.|%2e)1) [NC,OR]
RewriteCond %{QUERY_STRING} (s)?(ftp|inurl|php)(s)?(:(/|%2f|%u2215)(/|%2f|%u2215)) [NC,OR]
RewriteCond %{QUERY_STRING} (\.|20)(get|the)(_|%5f)(permalink|posts_page_url)(\(|%28) [NC,OR]
RewriteCond %{QUERY_STRING} ((boot|win)((\.|%2e)ini)|etc(/|%2f)passwd|self(/|%2f)environ) [NC,OR]
RewriteCond %{QUERY_STRING} (((/|%2f){3,3})|((\.|%2e){3,3})|((\.|%2e){2,2})(/|%2f|%u2215)) [NC,OR]
RewriteCond %{QUERY_STRING} (benchmark|char|exec|fopen|function|html)(.*)(\(|%28)(.*)(\)|%29) [NC,OR]
RewriteCond %{QUERY_STRING} (php)([0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12}) [NC,OR]
RewriteCond %{QUERY_STRING} (e|%65|%45)(v|%76|%56)(a|%61|%31)(l|%6c|%4c)(.*)(\(|%28)(.*)(\)|%29) [NC,OR]
RewriteCond %{QUERY_STRING} (/|%2f)(=|%3d|$&|_mm|cgi(\.|-)|inurl(:|%3a)(/|%2f)|(mod|path)(=|%3d)(\.|%2e)) [NC,OR]
RewriteCond %{QUERY_STRING} (<|%3c)(.*)(e|%65|%45)(m|%6d|%4d)(b|%62|%42)(e|%65|%45)(d|%64|%44)(.*)(>|%3e) [NC,OR]
RewriteCond %{QUERY_STRING} (<|%3c)(.*)(i|%69|%49)(f|%66|%46)(r|%72|%52)(a|%61|%41)(m|%6d|%4d)(e|%65|%45)(.*)(>|%3e) [NC,OR]
RewriteCond %{QUERY_STRING} (<|%3c)(.*)(o|%4f|%6f)(b|%62|%42)(j|%4a|%6a)(e|%65|%45)(c|%63|%43)(t|%74|%54)(.*)(>|%3e) [NC,OR]
RewriteCond %{QUERY_STRING} (<|%3c)(.*)(s|%73|%53)(c|%63|%43)(r|%72|%52)(i|%69|%49)(p|%70|%50)(t|%74|%54)(.*)(>|%3e) [NC,OR]
RewriteCond %{QUERY_STRING} (\+|%2b|%20)(d|%64|%44)(e|%65|%45)(l|%6c|%4c)(e|%65|%45)(t|%74|%54)(e|%65|%45)(\+|%2b|%20) [NC,OR]
RewriteCond %{QUERY_STRING} (\+|%2b|%20)(i|%69|%49)(n|%6e|%4e)(s|%73|%53)(e|%65|%45)(r|%72|%52)(t|%74|%54)(\+|%2b|%20) [NC,OR]
RewriteCond %{QUERY_STRING} (\+|%2b|%20)(s|%73|%53)(e|%65|%45)(l|%6c|%4c)(e|%65|%45)(c|%63|%43)(t|%74|%54)(\+|%2b|%20) [NC,OR]
RewriteCond %{QUERY_STRING} (\+|%2b|%20)(u|%75|%55)(p|%70|%50)(d|%64|%44)(a|%61|%41)(t|%74|%54)(e|%65|%45)(\+|%2b|%20) [NC,OR]
RewriteCond %{QUERY_STRING} (\\x00|(\"|%22|\'|%27)?0(\"|%22|\'|%27)?(=|%3d)(\"|%22|\'|%27)?0|cast(\(|%28)0x|or%201(=|%3d)1) [NC,OR]
RewriteCond %{QUERY_STRING} (g|%67|%47)(l|%6c|%4c)(o|%6f|%4f)(b|%62|%42)(a|%61|%41)(l|%6c|%4c)(s|%73|%53)(=|[|%[0-9A-Z]{0,2}) [NC,OR]
RewriteCond %{QUERY_STRING} (_|%5f)(r|%72|%52)(e|%65|%45)(q|%71|%51)(u|%75|%55)(e|%65|%45)(s|%73|%53)(t|%74|%54)(=|[|%[0-9A-Z]{2,}) [NC,OR]
RewriteCond %{QUERY_STRING} (j|%6a|%4a)(a|%61|%41)(v|%76|%56)(a|%61|%31)(s|%73|%53)(c|%63|%43)(r|%72|%52)(i|%69|%49)(p|%70|%50)(t|%74|%54)(:|%3a)(.*)(;|%3b|\)|%29) [NC,OR]
RewriteCond %{QUERY_STRING} (b|%62|%42)(a|%61|%41)(s|%73|%53)(e|%65|%45)(6|%36)(4|%34)(_|%5f)(e|%65|%45|d|%64|%44)(e|%65|%45|n|%6e|%4e)(c|%63|%43)(o|%6f|%4f)(d|%64|%44)(e|%65|%45)(.*)(\()(.*)(\)) [NC,OR]
RewriteCond %{QUERY_STRING} (@copy|\$_(files|get|post)|allow_url_(fopen|include)|auto_prepend_file|blexbot|browsersploit|(c99|php)shell|curl(_exec|test)|disable_functions?|document_root|elastix|encodeuricom|exploit|fclose|fgets|file_put_contents|fputs|fsbuff|fsockopen|gethostbyname|grablogin|hmei7|input_file|null|open_basedir|outfile|passthru|phpinfo|popen|proc_open|quickbrute|remoteview|root_path|safe_mode|shell_exec|site((.){0,2})copier|sux0r|trojan|user_func_array|wget|xertive) [NC,OR]
RewriteCond %{QUERY_STRING} (;|<|>|\'|\"|\)|%0a|%0d|%22|%27|%3c|%3e|%00)(.*)(/\*|alter|base64|benchmark|cast|char|concat|convert|create|encode|declare|delete|drop|insert|md5|order|request|script|select|set|union|update) [NC,OR]
RewriteCond %{QUERY_STRING} ((\+|%2b)(concat|delete|get|select|union)(\+|%2b)) [NC,OR]
RewriteCond %{QUERY_STRING} (union)(.*)(select)(.*)(\(|%28) [NC,OR]
RewriteCond %{QUERY_STRING} (concat)(.*)(\(|%28) [NC]
RewriteRule .* - [F,L]
# RewriteRule .* /7G_log.php?log [END,NE,E=7G_QUERY_STRING:%1___%2___%3]
</IfModule>
# 7G:[REQUEST URI]
RewriteCond %{REQUEST_URI} ([a-z0-9]{2000,}) [NC,OR]
RewriteCond %{REQUEST_URI} (=?\\(\'|%27)/?)(\.) [NC,OR]
RewriteCond %{REQUEST_URI} (\^|`|<|>|%|\\|\{|\}|\|) [NC,OR]
RewriteCond %{REQUEST_URI} (/)(\*|\"|\'|\.|,|&|&?)/?$ [NC,OR]
RewriteCond %{REQUEST_URI} (\.)(php)(\()?([0-9]+)(\))?(/)?$ [NC,OR]
RewriteCond %{REQUEST_URI} (/)(vbulletin|boards|vbforum)(/)? [NC,OR]
RewriteCond %{REQUEST_URI} (\.(s?ftp-?)config|(s?ftp-?)config\.) [NC,OR]
RewriteCond %{REQUEST_URI} (\{0\}|\"?0\"?=\"?0|\(/\(|\.\.\.|\+\+\+|\\\") [NC,OR]
RewriteCond %{REQUEST_URI} (thumbs?(_editor|open)?|tim(thumbs?)?)(\.php) [NC,OR]
RewriteCond %{REQUEST_URI} (/)(fck|ckfinder|fullclick|ckfinder|fckeditor) [NC,OR]
RewriteCond %{REQUEST_URI} (\.|20)(get|the)(_)(permalink|posts_page_url)(\() [NC,OR]
RewriteCond %{REQUEST_URI} (///|\?\?|/&&|/\*(.*)\*/|/:/|\\\\|0x00|%00|%0d%0a) [NC,OR]
RewriteCond %{REQUEST_URI} (/%7e)(root|ftp|bin|nobody|named|guest|logs|sshd)(/) [NC,OR]
RewriteCond %{REQUEST_URI} (/)(etc|var)(/)(hidden|secret|shadow|ninja|passwd|tmp)(/)?$ [NC,OR]
RewriteCond %{REQUEST_URI} (s)?(ftp|http|inurl|php)(s)?(:(/|%2f|%u2215)(/|%2f|%u2215)) [NC,OR]
RewriteCond %{REQUEST_URI} (/)(=|\$&?|&?(pws|rk)=0|_mm|_vti_|cgi(\.|-)?|(=|/|;|,)nt\.) [NC,OR]
RewriteCond %{REQUEST_URI} (\.)(ds_store|htaccess|htpasswd|init?|mysql-select-db)(/)?$ [NC,OR]
RewriteCond %{REQUEST_URI} (/)(bin)(/)(cc|chmod|chsh|cpp|echo|id|kill|mail|nasm|perl|ping|ps|python|tclsh)(/)?$ [NC,OR]
RewriteCond %{REQUEST_URI} (/)(::[0-9999]|%3a%3a[0-9999]|127\.0\.0\.1|localhost|loopback|makefile|pingserver|wwwroot)(/)? [NC,OR]
RewriteCond %{REQUEST_URI} (\(null\)|\{\$itemURL\}|cAsT\(0x|echo(.*)kae|etc/passwd|eval\(|self/environ|\+union\+all\+select) [NC,OR]
RewriteCond %{REQUEST_URI} (/)(awstats|(c99|php|web)shell|document_root|error_log|listinfo|muieblack|remoteview|site((.){0,2})copier|sqlpatch|sux0r) [NC,OR]
RewriteCond %{REQUEST_URI} (/)((php|web)?shell|crossdomain|fileditor|locus7|nstview|php(get|remoteview|writer)|r57|remview|sshphp|storm7|webadmin)(.*)(\.|\() [NC,OR]
RewriteCond %{REQUEST_URI} (/)(author-panel|bitrix|class|database|(db|mysql)-?admin|filemanager|htdocs|httpdocs|https?|mailman|mailto|msoffice|mysql|_?php-?my-?admin(.*)|tmp|undefined|usage|var|vhosts|webmaster|www)(/) [NC,OR]
RewriteCond %{REQUEST_URI} (\.)(7z|ab4|afm|aspx?|bash|ba?k?|bz2|cfg|cfml?|cgi|ctl|dat|db|dll|eml|et2|exe|fec|fla|hg|inc|ini|inv|jsp|log|lqd|mbf|mdb|mmw|mny|old|one|out|passwd|pdb|pl|psd|pst|ptdb|pwd|py|qbb|qdf|rar|rdf|sdb|sql|sh|soa|swf|swl|swp|stx|tar|tax|tgz|tls|tmd|wow|zlib)$ [NC,OR]
RewriteCond %{REQUEST_URI} (base64_(en|de)code|benchmark|child_terminate|curl_exec|e?chr|eval|function|fwrite|(f|p)open|html|leak|passthru|p?fsockopen|phpinfo|posix_(kill|mkfifo|setpgid|setsid|setuid)|proc_(close|get_status|nice|open|terminate)|(shell_)?exec|system)(.*)(\()(.*)(\)) [NC,OR]
RewriteCond %{REQUEST_URI} (/)(^$|00.temp00|0day|3xp|70bex?|admin_events|bkht|(php|web)?shell|configbak|curltest|db|dompdf|filenetworks|hmei7|index\.php/index\.php/index|jahat|kcrew|keywordspy|mobiquo|mysql|nessus|php-?info|racrew|sql|vuln|webconfig|(wp-)?conf(ig)?(uration)?|xertive)(\.php) [NC]
# RewriteRule .* /7G_log.php?log [END,NE,E=7G_REQUEST_URI:%1___%2___%3]
</IfModule>
# 7G:[USER AGENT]
RewriteCond %{HTTP_USER_AGENT} ([a-z0-9]{2000,}) [NC,OR]
RewriteCond %{HTTP_USER_AGENT} (<|%0a|%0d|%27|%3c|%3e|%00|0x00) [NC,OR]
RewriteCond %{HTTP_USER_AGENT} ((c99|php|web)shell|remoteview|site((.){0,2})copier) [NC,OR]
RewriteCond %{HTTP_USER_AGENT} (base64_decode|bin/bash|disconnect|eval|lwp-download|unserialize|\\\x22) [NC,OR]
RewriteCond %{HTTP_USER_AGENT} (360Spider|acapbot|acoonbot|ahrefs|alexibot|asterias|attackbot|backdorbot|becomebot|binlar|blackwidow|blekkobot|blexbot|blowfish|bullseye|bunnys|butterfly|careerbot|casper|checkpriv|cheesebot|cherrypick|chinaclaw|choppy|clshttp|cmsworld|copernic|copyrightcheck|cosmos|crescent|cy_cho|datacha|demon|diavol|discobot|dittospyder|dotbot|dotnetdotcom|dumbot|emailcollector|emailsiphon|emailwolf|exabot|extract|eyenetie|feedfinder|flaming|flashget|flicky|foobot|g00g1e|getright|gigabot|go-ahead-got|gozilla|grabnet|grafula|harvest|heritrix|httrack|icarus6j|jetbot|jetcar|jikespider|kmccrew|leechftp|libweb|linkextractor|linkscan|linkwalker|loader|masscan|miner|majestic|mechanize|mj12bot|morfeus|moveoverbot|netmechanic|netspider|nicerspro|nikto|ninja|nutch|octopus|pagegrabber|planetwork|postrank|proximic|purebot|pycurl|python|queryn|queryseeker|radian6|radiation|realdownload|rogerbot|scooter|seekerspider|semalt|siclab|sindice|sistrix|sitebot|siteexplorer|sitesnagger|skygrid|smartdownload|snoopy|sosospider|spankbot|spbot|sqlmap|stackrambler|stripper|sucker|surftbot|sux0r|suzukacz|suzuran|takeout|teleport|telesoft|true_robots|turingos|turnit|vampire|vikspider|voideye|webleacher|webreaper|webstripper|webvac|webviewer|webwhacker|winhttp|wwwoffle|woxbot|xaldon|xxxyy|yamanalab|yioopbot|youda|zeus|zmeu|zune|zyborg) [NC]
# RewriteRule .* /7G_log.php?log [END,NE,E=7G_USER_AGENT:%1]
</IfModule>
# 7G:[REMOTE HOST]
RewriteCond %{REMOTE_HOST} (163data|amazonaws|colocrossing|crimea|g00g1e|justhost|kanagawa|loopia|masterhost|onlinehome|poneytel|sprintdatacenter|reverse.softlayer|safenet|ttnet|woodpecker|wowrack) [NC]
# RewriteRule .* /7G_log.php?log [END,NE,E=7G_REMOTE_HOST:%1]
</IfModule>
# 7G:[HTTP REFERRER]
RewriteCond %{HTTP_REFERER} (semalt.com|todaperfeita) [NC,OR]
RewriteCond %{HTTP_REFERER} (ambien|blue\spill|cocaine|ejaculat|erectile|erections|hoodia|huronriveracres|impotence|levitra|libido|lipitor|phentermin|pro[sz]ac|sandyauer|tramadol|troyhamby|ultram|unicauca|valium|viagra|vicodin|xanax|ypxaieo) [NC]
# RewriteRule .* /7G_log.php?log [END,NE,E=7G_HTTP_REFERRER:%1]
</IfModule>
# 7G:[REQUEST METHOD]
RewriteCond %{REQUEST_METHOD} ^(connect|debug|move|trace|track) [NC]
# RewriteRule .* /7G_log.php?log [END,NE,E=7G_REQUEST_METHOD:%1]
</IfModule>
