[3.2][3.3][CDB] Header Links
Re: [3.2][3.3][CDB] Header Links
1.0.0_RC12 now available Image (replaces both 1.0.0 RC9 and 3.2.0 RC1)
Switches added for Moderator and Administrator view. These switches are taken from the phpBB code and work in exactly the same way. ie, if on any page an admin or mod can see the link to the ACP or MCP they then also see the link.
  • Disable Header Link in the ACP
  • Delete headerlink folder from the server
  • Upload the folder hifikabin to root/ext/
  • Enable it in the ACP
3.2.0-RC1 now available (for phpBB 3.2.x only) Image
More options added. You can now switch the extension off in the ACP (default is OFF. You will need to switch it on after installing this version) In addition the links can be placed under the header or in the NavBar. You can also decide whether to display all of the links on small screens instead of the drop down selector.
Compatible with my [3.2][3.3][RC] Sticky Bar Extension
This is now for phpBB 3.2.x as 3.1.x is almost EOL. Should you still be using 3.1.x, the 1.0.0 version of this extension will still be available here but I recommend that you move to 3.2.x at your earliest convenience.
3.2.0-RC2 now available (for phpBB 3.2.x only) Image
prosilver_se stylesheet added
Style Note:
  • If you wish to change the colour of the banner to suite your style, follow these instructions.
  • make a copy of hifikabin/headerlinks/styles/prosilver_se/ and give it the name of the style you are using
  • open hifikabin/headerlink/styles/stylename/theme/headerlink_not_navbar_color.css
  • change #828d96 to the hex color of your chouce
  • save>upload>enable the extension
3.2.1-RC1 now available
Important Note:
  • This version is written in a totally different way to those previously available and you MUST disable AND delete data before installing the current version. So remember to make a note of your existing button details first.
  • Delete the Data
3.2.1-RC2 now available
General tidy of code. The 'Link' button will not function on small devices that have JavaScript disabled and is hidden from view. The 'Under Header' option has been removed fro the main download in order to pass CDB validation. It is still available HERE as an addon to the main extension.
3.2.1-RC3 now available Compatible with phpBB 3.3.x Image Image
3.2.2-RC1 now available Restyled and Improved by cabot Image Image
3.2.2-RC2 now available Slight code improvement Image Image
3.2.2 Released to the CDB
