It was Japanese of your phpbb extension.
yamagami
Post by yamagami »
Nice to meet you. My name is yamagami2211.
I am a Japanese, English does not speak much. So, we use the machine translation (google translation).
Well, we were allowed to Japanese the extension of your crafted phpbb.
And Japanese localization, extension is a Google Search.
Download has to allow in [s]http://mk.f5.si//a9g3r[/s] .
The above link does not seem to be able to access. I'm sorry.
It issued a new link. Please use here.
https://goo.gl/TR5PjV
Re: It was Japanese of your phpbb extension.
Thank you, but the link you have posted does not work.
Can you please post the correct download link
yamagami
Post by yamagami »
It sounds like could not be connected to the link. I'm sorry.
It is a new link. https://goo.gl/TR5PjV
Administrator wrote:Thank you, but the link you have posted does not work.
Thank you, that link works perfectly. I will add the language files to my site.
Please note that the new version (3.1.0) has three extra language strings. If you would like to translate these, then it will be ready for release of the new version.
<?php
* @package phpBB Extension - Google Search
* @copyright (c) 2015 HiFiKabin
* @license http://opensource.org/licenses/gpl-2.0.php GNU General Public License v2
* DO NOT CHANGE
if (!defined('IN_PHPBB'))
   exit;
if (empty($lang) || !is_array($lang))
   $lang = array();
// DEVELOPERS PLEASE NOTE
// All language files should use UTF-8 as their encoding and the files must not contain a BOM.
// Placeholders can now contain order information, e.g. instead of
// 'Page %s of %s' you can (and should) write 'Page %1$s of %2$s', this allows
// translators to re-order the output of data while ensuring it remains correct
// You do not need this where single placeholders are used, e.g. 'Message %d' is fine
// equally where a string contains only two placeholders which are used to wrap text
// in a url you again do not need to specify an order e.g., 'Click %sHERE%s' is fine
// Some characters you may want to copy&paste:
$lang = array_merge($lang, array(
   'GOOGLE'                            => 'Google',
   'GOOGLE_SEARCH'                     => 'Google Search ...',
   'SEARCH_GOOGLE'                     => 'Google Search',
   'GOOGLESEARCH_NAVBAR'               => 'Navbar',
   'GOOGLESEARCH_HEADER'               => 'Header',
   'GOOGLESEARCH_INDEX'                => 'Index',
   'ACP_GOOGLESEARCH_CONFIG'           => 'Google Search',
   'ACP_GOOGLESEARCH_CONFIG_EXPLAIN'   => 'This is configuration page for the Google Search extension. .',
   'GOOGLESEARCH_VERSION'              => 'Version',
   'ACP_GOOGLESEARCH_CONFIG_SET'       => 'Configuration',
   'GOOGLESEARCH_CONFIG_SAVED'         => 'Google Search settings saved',
   'GOOGLESEARCH_CUSTOM'               => 'Custom Google Search',
   'GOOGLESEARCH_NOSCRIPT'             => 'JavaScript must be enabled and Google whitelisted in order to view the Custom Google Search Results',
   'GOOGLESEARCH_POSITION'             => 'Google Search Position',
   'GOOGLESEARCH_POSITION_EXPLAIN'     => 'Do you want to show the Search in the NavBar or Header?',
   'GOOGLESEARCH_CUSTOM_CODE'                   => 'Custom Code',
   'GOOGLESEARCH_CUSTOM_CODE_EXPLAIN'           => 'You can replace this default code with your own Search Engine ID if you wish',
   'GOOGLESEARCH_CUSTOM_CODE_PLACEHOLDER'       => 'Search Engine ID',
   'GOOGLESEARCH_VERIFICATION_CODE'                => 'Google Webmaster Tools Verification',
   'GOOGLESEARCH_VERIFICATION_CODE_EXPLAIN'        => 'You can enter your Google Verification Code here if you wish',
   'GOOGLESEARCH_VERIFICATION_CODE_PLACEHOLDER'    => 'Google Verification Code',
