Amazon Affiliate Demonstration
Ron
Re: Amazon Affiliate Demonstration
Post by Ron »
Hello,
i have a webspace with two forums in one database and for the first it works fine but for the second i cannot enter the affiliate-codes.
The error-message:
SQL ERROR [ mysqli ]
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
FILE: [ROOT]/phpbb/db/driver/driver.php
LINE: 855
CALL: trigger_error()
FILE: [ROOT]/phpbb/db/driver/mysqli.php
LINE: 193
CALL: phpbb\db\driver\driver->sql_error()
FILE: [ROOT]/phpbb/db/driver/factory.php
LINE: 329
CALL: phpbb\db\driver\mysqli->sql_query()
FILE: [ROOT]/phpbb/config/db.php
LINE: 161
CALL: phpbb\db\driver\factory->sql_query()
LINE: 122
CALL: phpbb\config\db->set_atomic()
FILE: [ROOT]/ext/hifikabin/amazonaffiliate/acp/amazonaffiliate_module.php
LINE: 33
CALL: phpbb\config\db->set()
FILE: [ROOT]/includes/functions_module.php
LINE: 674
CALL: hifikabin\amazonaffiliate\acp\amazonaffiliate_module->main()
FILE: [ROOT]/adm/index.php
LINE: 81
CALL: p_master->load_active()
Any idea?
Greetings
Ron
Ron
Post by Ron »
i just have deactivated the extension and again activated and now there will be shown the tag i hacked into the database directly via PMA!?
I suggest that you disable the extension, delete the data, and re install it.
That should correct any errors you have been getting
Ron
Post by Ron »
Thank you for your advice. What i wrote before made it also.
Good Work!
