Error SEO istemap
sofiene
Error SEO istemap
Post by sofiene »
I have install the SEO sitemap extension for my forum phpbb 3.3.2 from SEO Sitemap easy fix for 3.3.x
and when i activate it i have this error
The file "/home15/fjcwtkiu/public_html/forum/ext/shredder/sitemap/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 5 (near "- @config").
#0 /home15/fjcwtkiu/public_html/forum/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home15/fjcwtki...')
#1 /home15/fjcwtkiu/public_html/forum/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home15/fjcwtkiu/public_html/forum/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home15/fjcwtkiu/public_html/forum/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home15/fjcwtkiu/public_html/forum/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home15/fjcwtkiu/public_html/forum/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home15/fjcwtkiu/public_html/forum/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home15/fjcwtkiu/public_html/forum/phpbb/di/container_builder.php(212): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home15/fjcwtkiu/public_html/forum/common.php(115): phpbb\di\container_builder->get_container()
#9 /home15/fjcwtkiu/public_html/forum/adm/index.php(23): require('/home15/fjcwtki...')
#10 {main}
Any help for this problem and thanks
Re: Error SEO Sitemap
Administrator wrote: Sun May 17, 2020 11:28 am Offered "as is" no support given
If you follow the instructions exactly as I posted in that topic the extension will work (it is working here).
Restore your backup files, then try again EXACTLY as described in the topic.
That is all the support I can give as it is not my extension and I only hosted the fix files as a general help. If you are still having issues then you should remove the extension until such time as the author offers support.
