Hi... yes.... me again!
Just really digging your Extensions!
I installed the random header image and curious if there is a way to overlay the forum title and description over the picture. currently only get the logo.
I know alternately i could put that info within each picture of course.
dave
Random Header Image
Re: Random Header Image
I assume you mean Random Banner
Unzip the attached and use to replace the styles directory of Random Banner as usual.(you know the drill by now)
I have set the default so that it shows correctly next to the default logo, but should you need to adjust the position of the text relative to the logo (or have no logo at all)
styles/prosilver/theme/randombanner.css
FIND (on line 20)
Adjust as needed, save, upload, purge BROWSERS cache
FIND (on line 20)
margin-left: 180px;
Yes.... ahhh random header banner... yes sorry,
That works perfect thanks!
Hi there,
OK so you seem to know your stuff pretty well here. I have the style Absolution installed on my 2nd forum. along with random header banner. i have the search box in the navbar. But it shows like the picture. colors are gone! The style author is not very helpful at all. i have had 3 other color issues that i figured out myself. but this one is evading me. not sure if its the Extension or the Style. When i "inspect" the icons the colors that should work are crossed off?
EDIT: ok so im 90 percent sure its the style messing things up.... u have any idea where to look?
absolution/theme/colors.css
you are looking for #search-box
