Sticky navbar
dave c
Sticky navbar
Post by dave c »
Hi again,
OK i installed the sticky so far on my live forum. I activated the search bar in navbar. but it displays in the header till u scroll down and then it moves to the navbar. is there any way to permanently move it to the navbar?
I did try your search in navbar extension but it displays a whole new line when i have the menubar activated with the buttons in navbar option. all other options display properly.
dave c
Re: Sticky navbar
Post by dave c »
im thinking its an order of operations thing.... seems like we gotta get the search to display first the then the menu buttons?
Re: Sticky navbar
Not so much an order of operation but each extension being handled separately.
Download and unzip the attached
Disable, delete data and remove the files for NavBar Search
Disable Sticky Bar
UPLOAD
stickybar.css
TO
hifikabin/stickybar/styles/prosilver/theme
overwriting that file thats already there
Enable Sticky Header and purge your BROWSERS cache.
If that doesn't show properly with the header links I'll have to look at doing it another way, just let me know
stickybar.zip
EDIT Mail bounced back again :roll:
dave c
Re: Sticky navbar
Post by dave c »
No that didnt work.... actually no search bar at all now!. :(
let me try and change my email to the one we host at work. it should let it go.
Re: Sticky navbar
:oops: ... and turn Sticky Bar Search to "on"
dave c
Re: Sticky navbar
Post by dave c »
Yes i have that setting turned to "on" search bar go bye bye!
on a good note my mew email works correctly.
I have had email isssues on other sites from over the pond with email not working. one author named Oxpus in Germany, i never got any from his site either! gonna use this one i think from now on.
Re: Sticky navbar
How weird, its working perfectly in my test environment.
Lets do it a different way. Download and unzip the attached,
Disable Header Link
UPLOAD
styles to overwrite the same directory in Header Link
Enable the Extension
Purge the Browsers cache
Cross the fingers :wink:
styles.zip
dave c
Re: Sticky navbar
Post by dave c »
Ok,
I will try that today.
As another note: your last tweak works for the search bar to stay in the navbar all the time but only when the buttons are set "in header" or "below header" but for some reason not "in navbar" :smt017
Re: Sticky navbar
Thats down to code blocks clashing (or not) Its always likely to happen when you have more than one extension trying to use the same space in the template.
dave c
Re: Sticky navbar
Post by dave c »
SO Close!
so only problem is that it aligns next to the buttons. can we get it to align right?
