Great work. I already have some extensions from you in use. Thank you very much!
Is there a way to put the forum title with the forum description in the header banner? Sorry for my English.
Random Header Banner
Re: Random Header Banner
I am afraid that it is not possible at present due to the way the extension is written. The easiest way would be for you to add your logo to each banner so that it looks similar to this
As long as the banners are the same physical size and you are careful with your logo placement there should be no problems.
I created it with https://lunapic.com/ its free and very easy to use.
Thanks for the tip. First I put a text over the pictures. How about a watermark, which is integrated via the extension? Would that be feasible?
Again you would probably be better off adding a copyright to the image directly.
Its certainly 'doable' but like adding the Site Logo it would need quite a bit of re working of the extension.
I have done some playing around and if you are happy with a hack of this extension this will add your site logo above ALL banners.
Download and unzip the attached, then upload it to the event directory of this extension, purge the cache and it should work as you want.
Aha, just finished with my changes to the photos. https://forum.peugeot-metropolis.de
Thank you very much. Of course the innovation will be tested soon. I'll report later.
I was overthinking the problem. Making the existing logo show is an easy edit. I may add a switch for that in future versions.
That would be great! Have a happy new year!
I copied the file into the extension directory, but I don't see any way to set anything.Administrator wrote: ↑Mon Dec 31, 2018 1:37 pm I have done some playing around and if you are happy with a hack of this extension this will add your site logo above ALL banners.
overall_header_headerbar_after.zip
Its so long ago I can not remember what I did
To be honest I had forgotten about this, but I have got it working on my Header banner Extension and it shouldn't be a problem to add it to the Random Banner.
I'll play with my test forum and get back to you.
