I have installed the Obscure Contact Us extension for my v3.22 board. I have enabled it and saved settings and flushed the cache. As far as I can see it only hides the link and disables the form. I achieve his by simply disabling the contact form in the standard admin control. It's not clear what the extension should be doing.
Any help would be appreciated.
Thanks,
Bob.
Obscure Contact Us Ext
Re: Obscure Contact Us Ext
Hi Bob
Yes, that is its behaviour upon install. You must then go to the ACP>Extensions tab to set the link details.
Once you have submitted this form, the link will be visible in a way that makes it invisible to bots.
