Header Banner, can't get it to work
Leia_the_rebel
Post by Leia_the_rebel »
So, I was able to get the extension to show up in the Admin Pannel. but when i put the image link in the spot for it, it dose not show up. the default banner is still there... and yes i did hit the activate the exstention. I'm using imgur as the image host. can you help you figure out what I'm doing wrong!
Re: Header Banner, can't get it to work
What style are you using and can I have a link to your forum?
Leia_the_rebel
I'm using win10
and here is the link http://www.silvermillenniumfalcon.com/index.php
I have just tried it with the W10 style, and it is a complete mess. I may be able to make it compatible, but I am busy for the next few days.
Once I have looked into the code I'll post an update
Leia_the_rebel
okay, thanks for the help
Leia_the_rebel
I've descended to go with a diffrent style as another extension also dose not work with the win 10. it caused fatal error with win.10.
i found some other possible styles that work with the banner.
OK, I'l consider this closed for now, but I have worked out a way to get my Header Banner Ext working with win10 should you want it in the future
Leia_the_rebel
okay, so i could not find any other style i liked and i ended up finding an updated version of win 10 dark. Which works with the Ext. but thank you for all your help and hard work.
https://www.phpbb.com/community/viewtop ... &t=2403406
Leia_the_rebel
Sorry to double post, but I just realized some of the link, the PM or log in. can not be clicked on when the banner is there. dose it have to do with the style code? I'd like to try that updated version of the ext. you made
What I have done is edit the overall_header.html in the win10 style. Download and unzip the attached, upload it to replace the one in win10 then purge the cache.
Then enable Header banner and all should be as you want it. If there are any problems, just reverse the above and let me know.
overall_header.zip
