Your Bad Bot File
Dana-Tucker
Your Bad Bot File
Post by Dana-Tucker »
I loved your explanation for SEO! I have downloaded your bad bot file for non ssl. I also run my phpbb forum off of my WordPress site hosted with GoDaddy. www.YourPodcastReview.Com/forum. Would your file work on the root directory for my main site as well?
Re: Your Bad Bot File
Yes, the list of bad bots will work for any site. Use the raw list and add it to your existing .HTACCESS
You have to do it that way as using the .HTACCESS file here will overwrite any existing .HTACCESS rules you may have and need in the root. Just add the list on a new line. Use a text editor, not a wordprocessor. I use http://www.pspad.com/en/ which is freeware.
