Header Links needs fixes and FRENCH translation
Galixte de EzCom
Post by Galixte de EzCom »
if the name of the extension should be : “Header Links”, i think there are some language keys (ACP_HEADERLINK, ACP_HEADERLINK_CONFIG, ACP_HEADERLINK_CONFIG_EXPLAIN, HEADERLINK_CONFIG & HEADERLINK_SAVED) those should be changed to : Header Links instead of Header Link (s is missing). Also, you have to fix the name of the folder, and two informations in composer.json and PHP files to be consistent.
About, the language key : ACP_HEADERLINK_ICON it’s not displayed in ACP, why, i think this sentence is usefull, also if the link to this website: http://fontawesome.io/ is indicated.
  1. OPEN: ./ext/hifikabin:headerlink/adm/style/acp_headerlink_config.html
  2. FIND ( line 8 ): <label>{L_ACP_HEADERLINK_EXT_URL}</label></p>
  3. AFTER, ADD ( on a new line ): <label>{L_ACP_HEADERLINK_ICON}</label></p>
  4. SAVE, CLOSE & PURGE THE BOARD CACHE
Good luck !
Last edited by Galixte de EzCom on Thu Jun 08, 2017 3:50 pm, edited 3 times in total.
Communau EzCom
« Traductions d’extensions & styles pour phpBB 3.2.x & 3.3.x ».
Re: Header Links needs fixes and FRENCH translation
Thanks for that. As I said on your other topic, things are on hold right now but I will certainly look at this again before release.
Galixte de EzCom
FRENCH translation for the Header Links extension
This is the FRENCH translation for the Header Links extension, available on EzCom Community.
Communau EzCom
