Can't search something keyword
Lichang
Post by Lichang » Wed May 03, 2017 3:16 am
I post a topic and content like below
RCN 223F、227F、723F、727F、827F、2390F、2590F、5390F、5590F、8390F、8590F
ROC 400F
ECN 400F
EQN 400F
ROQ 400F
i test to search key word like 223 or 227
the result is nothing
but when i test to search 223f or 227f or 223*
it can find keyword
Another problem is how could i search by multi keyword (like 223 and 727)
have anybody can answer me about this???
Re: Can't search something keyword
Post by Administrator » Wed May 03, 2017 8:34 am
As Amigo Jack stated on the phpBB forum, its probably due to the way the search ignores certain terms. Have you tried my Google Search extension? As long as you set the custom search correctly that may be an answer to your problem.
Try it and see, but remember that Google will have to index your site first
lichang422
Post by lichang422 » Wed May 03, 2017 11:11 am
i tested about google search
i had some question
i had installed extend and enable it,i can see google bar in advance search
but when i try to search,it search keyword of global
1. Could i setting search just for my web???
2. I had setting extend about google search page,Custom Google Search was changed to my Engine ID, The result is found nothing
3. Google Webmaster Tools Verification ,should i need to set ???
I will be grateful for any help you can provide
lichang422
Post by lichang422 » Wed May 03, 2017 11:29 am
Actually i want to know why your web can search by embedded search bar
and i tested multi keyword ,also can find something
But my web can't .T_T
My system is php3.2,search engine is phpBB Native Fulltext
Post by Administrator » Wed May 03, 2017 11:37 am
i had some question
Yes, you can set the Google Search to search just your site by adding your Google Search ID as you mentioned in point 2. However, remember that it will not work until Google has totally indexed your site, which may take hours or even days depending on how much content it has to index.
The Google Verification code can be left empty as it has no effect on the search. Its sole purpose is to show your site ownership to Google without you having to add the Google Search Verification file.
To show the Google Search on the forum page, you need to select the position in the ACP
lichang422
Post by lichang422 » Wed May 03, 2017 1:29 pm
i had some question
Thank you for answer!!
I will test result later!! :smt007 :smt007
Another problem,if google search been setting success , Could i hide original search bar???
lichang422
Post by lichang422 » Wed May 03, 2017 2:34 pm
I find one question,when I use mobile type to see my web,i can't find Google bar,i need to change to computer type
Post by Administrator » Wed May 03, 2017 4:13 pm
Yes, you can disable the native search in the ACP Search settings
The Google Search Bar is hidden by default on small devices. To show it on everything, disable Google Search
Download and unzip the attached, upload it to your server overwriting the files when prompted, then re enable
lichang422
Post by lichang422 » Mon May 08, 2017 2:35 pm
It's so terrible, i had wait 4 days!!
But i can't find anything!!
Can u help me to check problem???
Post by Administrator » Wed May 10, 2017 4:41 pm
I am afraid that I do not really know. Maybe its a language issue.
Sorry
